Einleitung
Replacing the keyboard is a quick and easy task. Removing the keyboard only took three tools: A JIS #1 screwdriver, plastic opening tool, and tweezers. Before you start make sure you remove the battery and unplug the device.
Was du brauchst
At the top of the laptop you will see two switches, like in image one and two.
Pull the switches outwards with your thumb, towards the unlocked lock.
Wedge the plastic opening tool in-between the keyboard and the base of the laptop.
Continue using the plastic opening tool to pry around the edge until the keyboard is completely freed form the frame.
The keyboard should only be connected by a ribbon on the underside of the keyboard.
Use the tweezers to lift the black hinge on the ribbon connector.
Then pull the ribbon from the connector and remove the keyboard from the laptop.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
