Einleitung
Replacing the screen is a quick and easy task. Removing the screen only takes three tools: A JIS #0 screwdriver, a plastic opening tool, and a spudger. Before you start make sure you remove the battery and unplug the device.
Was du brauchst
At the top of the laptop you will see two switches, like in image one and two.
Pull the switches outwards with your thumb, towards the unlocked lock.
Use the plastic opening tool to pry the plastic away from the screen.
Unscrew the four 7mm screws located on all four corners of the frame using a JIS #0 screwdriver.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
2 Kommentare
Thanks alot…..I just fixed my screen by God's grace.
Hi! Is it possible to replace the screen with 1080p LCD?
