Zum Hauptinhalt wechseln
Lenovo G40-30 LCD Screen Replacement
Was du brauchst
  1. Lenovo G40-30 LCD Screen Replacement, Battery: Schritt 1, Bild 1 von 3 Lenovo G40-30 LCD Screen Replacement, Battery: Schritt 1, Bild 2 von 3 Lenovo G40-30 LCD Screen Replacement, Battery: Schritt 1, Bild 3 von 3
    • At the top of the laptop you will see two switches, like in image one and two.
    • Pull the switches outwards with your thumb, towards the unlocked lock.
  2. Lenovo G40-30 LCD Screen Replacement: Schritt 2, Bild 1 von 3 Lenovo G40-30 LCD Screen Replacement: Schritt 2, Bild 2 von 3 Lenovo G40-30 LCD Screen Replacement: Schritt 2, Bild 3 von 3
    • Once both switches are pulled, the battery should pop out.
  3. Lenovo G40-30 LCD Screen Replacement: Schritt 3, Bild 1 von 1
    • Now you are ready to insert your new battery.
  4. Lenovo G40-30 LCD Screen Replacement, LCD Screen: Schritt 4, Bild 1 von 2 Lenovo G40-30 LCD Screen Replacement, LCD Screen: Schritt 4, Bild 2 von 2
    • Use the plastic opening tool to pry the plastic away from the screen.
  5. Lenovo G40-30 LCD Screen Replacement: Schritt 5, Bild 1 von 2 Lenovo G40-30 LCD Screen Replacement: Schritt 5, Bild 2 von 2
    • Carefully unsnap the front plastic piece to expose the frame of the screen.
  6. Lenovo G40-30 LCD Screen Replacement: Schritt 6, Bild 1 von 3 Lenovo G40-30 LCD Screen Replacement: Schritt 6, Bild 2 von 3 Lenovo G40-30 LCD Screen Replacement: Schritt 6, Bild 3 von 3
    • Unscrew the four 7mm screws located on all four corners of the frame using a JIS #0 screwdriver.
    • Carefully lift the screen from the base so as to not damage it.
  7. Lenovo G40-30 LCD Screen Replacement: Schritt 7, Bild 1 von 2 Lenovo G40-30 LCD Screen Replacement: Schritt 7, Bild 2 von 2
    • Slowly remove the sticker connected to the rear of the screen using a spudger.
    • Carefully disconnect the screen from the base of the laptop.
  8. Lenovo G40-30 LCD Screen Replacement: Schritt 8, Bild 1 von 1
    • Now you have removed the screen and are ready to install a new one.
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
Sam Houston State, Team S16-G4, Nardone Spring 2018 Mitglied von Sam Houston State, Team S16-G4, Nardone Spring 2018
SHSU-NARDONE-S18S16G4
5 Mitglieder
5 Anleitungen geschrieben
2 Kommentare
Thanks alot…..I just fixed my screen by God's grace.
Nnaemeka Okechukwu - Antwort
Hi! Is it possible to replace the screen with 1080p LCD?
Chin Yau Chia - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 4
Letzte 7 Tage: 13
Letzte 30 Tage: 19
Insgesamt: 2,468
