Einleitung
When connecting to the internet, the computer should see the available wifi signals. If it cannot find any signals, the wireless card could be the problem.
Was du brauchst
Push the left switch (labeled 1) to the left to show red underneath. This will unlock battery.
Push the right switch (labeled 2) to the right. This will eject battery.
Remove the three 6mm Phillips #0 screws holding the back access panel on.
Slide the cover toward you to unlatch it.
The edge of the panel will slide away from the laptop so it can be lifted.
Disconnect the two plugs on the wireless card by pulling them up with a small tool.
6 weitere Nutzer:innen haben diese Anleitung absolviert.
