Zum Hauptinhalt wechseln
Lenovo G50-80 80E5 Fan Replacement
Was du brauchst
  1. Lenovo G50-80 80E5 Fan Replacement, Battery: Schritt 1, Bild 1 von 1
    • Place laptop on a flat surface with the back cover facing up and the hinges facing you.
  2. Lenovo G50-80 80E5 Fan Replacement: Schritt 2, Bild 1 von 3 Lenovo G50-80 80E5 Fan Replacement: Schritt 2, Bild 2 von 3 Lenovo G50-80 80E5 Fan Replacement: Schritt 2, Bild 3 von 3
    • Slide the tab positioned on the right side to the right.
    • You will know this has been done correctly when you can see the red surface beneath the tab.
  3. Lenovo G50-80 80E5 Fan Replacement: Schritt 3, Bild 1 von 3 Lenovo G50-80 80E5 Fan Replacement: Schritt 3, Bild 2 von 3 Lenovo G50-80 80E5 Fan Replacement: Schritt 3, Bild 3 von 3
    • Move the left tab to the left to release the battery.
    • You will hear an audible 'click' and see the battery separate from the rest of the laptop.
  4. Lenovo G50-80 80E5 Fan Replacement: Schritt 4, Bild 1 von 3 Lenovo G50-80 80E5 Fan Replacement: Schritt 4, Bild 2 von 3 Lenovo G50-80 80E5 Fan Replacement: Schritt 4, Bild 3 von 3
    • Hold the battery at the top seam between it and the laptop.
    • Roll the battery towards yourself.
    • Lift the battery out of the laptop.
  5. Lenovo G50-80 80E5 Fan Replacement, Bottom Access Panel: Schritt 5, Bild 1 von 2 Lenovo G50-80 80E5 Fan Replacement, Bottom Access Panel: Schritt 5, Bild 2 von 2
    • Remove the three screws securing the outer cover of the laptop using a Phillips #0 screwdriver.
  6. Lenovo G50-80 80E5 Fan Replacement: Schritt 6, Bild 1 von 2 Lenovo G50-80 80E5 Fan Replacement: Schritt 6, Bild 2 von 2
    • Slide the cover away from the hinges and lift the panel off.
  7. Lenovo G50-80 80E5 Fan Replacement, Fan: Schritt 7, Bild 1 von 1
    • Rotate the laptop so that you are positioned over the fan.
  8. Lenovo G50-80 80E5 Fan Replacement: Schritt 8, Bild 1 von 1
    • Remove the three 6 mm screws securing the fan using a Phillips #00 screwdriver.
  9. Lenovo G50-80 80E5 Fan Replacement: Schritt 9, Bild 1 von 1
    • Unplug the cable from the tri-color end connected to the motherboard.
  10. Lenovo G50-80 80E5 Fan Replacement: Schritt 10, Bild 1 von 1
    • Remove the fan from the laptop.
Abschluss
2 weitere Personen haben diese Anleitung absolviert.
Noah Baldwin
350 Reputation
3 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 16
Insgesamt: 517
