Einleitung
The Lenovo G50-80 80E5 was released in 2015. As laptops are used over time, they experience general wear and tear, and certain hardware will need to be replaced. If your laptop is struggling to boot up, you may be experiencing a hard drive failure and need to do a replacement. As well as experiencing a hard drive failure, one may choose to upgrade their hard drive for increased speed, processing power, and memory. Multimedia is a growing form, and an upgraded hard drive will be capable of storing far more photos, movies, etc. If either of these scenarios apply to you, refer to this guide to disassemble your Lenovo G50-80 80E5 in order to remove and replace your hard drive.
Your laptop will need to be turned off and removed from any external power sources such as the laptop's charger.
Was du brauchst
Place laptop on a flat surface with the back cover facing up and the hinges facing you.
Move the left tab to the left to release the battery.
You will hear an audible 'click' and see the battery separate from the rest of the laptop.
Hold the battery at the top seam between it and the laptop.
Roll the battery towards yourself.
Lift the battery out of the laptop.
Remove the three screws securing the outer cover of the laptop using a Phillips #0 screwdriver.
Use the #00 Phillips screwdriver to remove the four 5.5mm screws around the hard drive.
If you would like to reassemble your device, please follow these instructions in reverse order.
3 weitere Nutzer:innen haben diese Anleitung absolviert.
