Einleitung
You will learn how to remove the hard drive from your Lenovo G50-80 80E5 laptop for replacement.
Was du brauchst
Remove the three screws securing the outer cover of the laptop using a Phillips #0 screwdriver.
Locate the 4 #00-5.5 mm Phillips screws securing the hard drive into the laptop.
Remove the 4 screws with the #00 Phillips screwdriver
With the screws removed, slide the hard drive away from the center of the laptop and remove it.
3 weitere Personen haben diese Anleitung absolviert.
