Was du brauchst
Place laptop on a flat surface with the back cover facing up and the hinges facing you.
Move the left tab to the left to release the battery.
You will hear an audible 'click' and see the battery separate from the rest of the laptop.
Hold the battery at the top seam between it and the laptop.
Roll the battery towards yourself.
Lift the battery out of the laptop.
Remove the three screws securing the outer cover of the laptop using a Phillips #0 screwdriver.
Locate the 3 screws on the bottom, securing the keyboard.
One Screw will be located under Lenovo sticker. Break sticker to gain access to screw.
Using tweezers, lift up clip to remove keyboard ribbon cable.
Keyboard ribbon cable removed
Once ribbon is removed, keyboard can be lifted out
remove power cable with tweezers by gently pullying
Locate the 3 screws holding fan in place
Remove 3 screws
fan should lift out of place
Once screws are removed, begin by gently prying up in one corner using a spudge
Continue to center and then around to opposite side.
once all sides have been pried open, lift top half off
12 weitere Personen haben diese Anleitung absolviert.
