Zum Hauptinhalt wechseln
Lenovo G575 Fan Replacement
Was du brauchst
  1. Lenovo G575 Fan Replacement, Fan: Schritt 1, Bild 1 von 1
    • Use the two switches to the left of and below the battery to unlock and release the battery.
    • The switch on the left should be moved to the left to unlock, then the switch on the right will release the battery.
    • Remove the battery from the laptop by lifting it out from its bay.
  2. Lenovo G575 Fan Replacement: Schritt 2, Bild 1 von 1
    • Use a Phillips #0 screwdriver to remove the five screws from the service panel on the right side.
    • Lift up the service panel.
  3. Lenovo G575 Fan Replacement: Schritt 3, Bild 1 von 1
    • Using a Phillips #0 screwdriver, remove the three silver screws holding the fan down.
    • Pull out the fan cable from its connector on the motherboard.
    • Lift the fan out of the case.
Abschluss
Samson Wong
103 Reputation
1 Anleitung geschrieben
York University, Team S1-G75, Woodhouse Fall 2020 Mitglied von York University, Team S1-G75, Woodhouse Fall 2020
YORK-WOODHOUSE-F20S1G75
1 Mitglied
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 3
Insgesamt: 858
