Was du brauchst
Use the two switches to the left of and below the battery to unlock and release the battery.
Remove the battery from the laptop by lifting it out from its bay.
Use a Phillips #0 screwdriver to remove the five screws from the service panel on the right side.
Lift up the service panel.
Using a Phillips #0 screwdriver, remove the three silver screws holding the fan down.
Pull out the fan cable from its connector on the motherboard.
Lift the fan out of the case.
