Zum Hauptinhalt wechseln
Lenovo G580 Battery Replacement
Was du brauchst
  1. Lenovo G580 Battery Replacement, Battery: Schritt 1, Bild 1 von 1
    • Make sure your laptop is oriented backside facing upward as seen in the image.
    • Locate the battery lock switch.
  2. Lenovo G580 Battery Replacement: Schritt 2, Bild 1 von 2 Lenovo G580 Battery Replacement: Schritt 2, Bild 2 von 2
    • Unlock the battery by moving the switch to the right.
    • The switch is unlocked when the RED of the switch is present.
  3. Lenovo G580 Battery Replacement: Schritt 3, Bild 1 von 2 Lenovo G580 Battery Replacement: Schritt 3, Bild 2 von 2
    • Hold the release switch down.
    • At the same time, push the battery upwards to remove the battery.
    • Pulling on the battery while the battery is locked will damage the laptop. Ensure the lock is properly disengaged.
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 3
Letzte 30 Tage: 25
Insgesamt: 1,745
