Einleitung
Batteries lose their ability to hold their charge over long periods of use. This results in the user needing to replace the battery to maintain sufficient battery life. This guide requires no tools.
Was du brauchst
Make sure your laptop is oriented backside facing upward as seen in the image.
Locate the battery lock switch.
Hold the release switch down.
At the same time, push the battery upwards to remove the battery.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
