Einleitung
Keyboard keys can be damaged through extensive use or spills. It is important to be able to replace missing keys as a keyboard is unusable without all keys in working order. This is a simple task that only requires a spudger and a few minutes of time.
Was du brauchst
Gently pull upwards with the prying tool until the key comes off.
Use your hand to remove the key once the key is fully released.
To replace the key, place the key above its mechanism and gently press it into place.
