Was du brauchst
Turn off the computer.
Set the computer upside down with the back facing up.
With the battery facing you, slide the battery switch on the right side of the laptop towards the right.
Slide the left battery release switch to the left.
While holding the switch to the left, lift the battery to remove it from the computer.
Use a plastic opening tool to pull the bezel forward and release it from the top of the LCD panel.
After the top part of the bezel is released, use the plastic opening tool to completely remove the bezel.
Use a screwdriver to remove the screws that secure the LCD panel to the computer.
Carefully separate the LCD panel from the plastic cover, placing it face down on the keyboard
With a screwdriver, remove the four screws that mount the LCD panel onto the mounting arms.
2 weitere Personen haben diese Anleitung absolviert.
Ein Kommentar
how do you repair a whitescreen effect for a lenovo110 ideapad
