Zum Hauptinhalt wechseln
Lenovo G780 Heat Sink Replacement
Was du brauchst
  1. Lenovo G780 Heat Sink Replacement, Battery: Schritt 1, Bild 1 von 2 Lenovo G780 Heat Sink Replacement, Battery: Schritt 1, Bild 2 von 2
    • Turn off the computer.
    • Slide the battery-lock switch on the bottom of the laptop to the unlocked position.
  2. Lenovo G780 Heat Sink Replacement: Schritt 2, Bild 1 von 1
    • Hold the battery release switch in the unlocked position and remove the battery.
  3. Lenovo G780 Heat Sink Replacement, Fan: Schritt 3, Bild 1 von 3 Lenovo G780 Heat Sink Replacement, Fan: Schritt 3, Bild 2 von 3 Lenovo G780 Heat Sink Replacement, Fan: Schritt 3, Bild 3 von 3
    • Remove the six 9 mm screws from the back panel with a Phillips #0 screwdriver.
    • Save these screws.
    • Remove the back plate.
  4. Lenovo G780 Heat Sink Replacement: Schritt 4, Bild 1 von 1
    • Use a Phillips #0 screwdriver to detach the fan by removing the two black 9 mm screws and the single silver 4 mm screw that is securing it to the motherboard.
  5. Lenovo G780 Heat Sink Replacement: Schritt 5, Bild 1 von 2 Lenovo G780 Heat Sink Replacement: Schritt 5, Bild 2 von 2
    • Carefully disconnect the fan cable from its socket on the motherboard.
    • The fan should now be completely free from the laptop motherboard and chassis.
  6. Lenovo G780 Heat Sink Replacement, Heat Sink: Schritt 6, Bild 1 von 3 Lenovo G780 Heat Sink Replacement, Heat Sink: Schritt 6, Bild 2 von 3 Lenovo G780 Heat Sink Replacement, Heat Sink: Schritt 6, Bild 3 von 3
    • Remove three 7mm spring loaded screws using a Phillips #1 screwdriver.
    • Remove these two 4 mm screws using a Phillips #1 screwdriver.
  7. Lenovo G780 Heat Sink Replacement: Schritt 7, Bild 1 von 2 Lenovo G780 Heat Sink Replacement: Schritt 7, Bild 2 von 2
    • The heat sink needs to be rotated counter-clockwise slightly to allow space for removal.
Abschluss
Riley Griffin
316 Reputation
3 Anleitungen geschrieben
IUPUI, Team S2-G4, Henning Spring 2019 Mitglied von IUPUI, Team S2-G4, Henning Spring 2019
IUPUI-HENNING-S19S2G4
3 Mitglieder
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 3
Insgesamt: 604
