Einleitung
The heatsink of your laptop may be faulty if you notice your fan is running more than normal, or if your laptop is getting excessively hot during normal use.
Was du brauchst
Turn off the computer.
Slide the battery-lock switch on the bottom of the laptop to the unlocked position.
Hold the battery release switch in the unlocked position and remove the battery.
Remove the six 9 mm screws from the back panel with a Phillips #0 screwdriver.
Remove the back plate.
Use a Phillips #0 screwdriver to detach the fan by removing the two black 9 mm screws and the single silver 4 mm screw that is securing it to the motherboard.
Remove three 7mm spring loaded screws using a Phillips #1 screwdriver.
Remove these two 4 mm screws using a Phillips #1 screwdriver.
The heat sink needs to be rotated counter-clockwise slightly to allow space for removal.
