Einleitung
If you wish to upgrade or replace RAM on the Lenovo G780, follow this guide.
Was du brauchst
Turn off the computer.
Slide the battery-lock switch on the bottom of the laptop to the unlocked position.
Hold the battery release switch in the unlocked position and remove the battery.
Using a #0 Phillips screwdriver, remove the six 9mm panel screws from the bottom of the device.
Push the two locks outwards to release the RAM.
Carefully pull the RAM module from its socket.
