Zum Hauptinhalt wechseln
Lenovo IdeaCentre AIO 510S-23ISU Arm Stand Replacement
Was du brauchst
  1. Lenovo IdeaCentre AIO 510S-23ISU Arm Stand Replacement, Stand Base: Schritt 1, Bild 1 von 1
    • Turn off the computer, unplug all cables, and let it cool down. Lay the computer flat on its screen.
    • Make sure that the work surface is flat and has nothing sharp on it.
  2. Lenovo IdeaCentre AIO 510S-23ISU Arm Stand Replacement: Schritt 2, Bild 1 von 2 Lenovo IdeaCentre AIO 510S-23ISU Arm Stand Replacement: Schritt 2, Bild 2 von 2
    • Remove the monitor stand screw in the bottom of the stand, and remove the stand completely.
  3. Lenovo IdeaCentre AIO 510S-23ISU Arm Stand Replacement, Back Cover: Schritt 3, Bild 1 von 1
    • Remove the two screws on the bottom of the computer, one on each side.
  4. Lenovo IdeaCentre AIO 510S-23ISU Arm Stand Replacement: Schritt 4, Bild 1 von 3 Lenovo IdeaCentre AIO 510S-23ISU Arm Stand Replacement: Schritt 4, Bild 2 von 3 Lenovo IdeaCentre AIO 510S-23ISU Arm Stand Replacement: Schritt 4, Bild 3 von 3
    • Locate the slot on the right side of the computer next to the screw hole. Use a plastic opening tool or spudger to pry off the rear cover. (Don’t be afraid to use a little force.)
  5. Lenovo IdeaCentre AIO 510S-23ISU Arm Stand Replacement: Schritt 5, Bild 1 von 2 Lenovo IdeaCentre AIO 510S-23ISU Arm Stand Replacement: Schritt 5, Bild 2 von 2
    • Once it has been separated, lift to remove.
  6. Lenovo IdeaCentre AIO 510S-23ISU Arm Stand Replacement, Arm Stand: Schritt 6, Bild 1 von 2 Lenovo IdeaCentre AIO 510S-23ISU Arm Stand Replacement, Arm Stand: Schritt 6, Bild 2 von 2
    • Remove the four screws that secure the arm stand.
  7. Lenovo IdeaCentre AIO 510S-23ISU Arm Stand Replacement: Schritt 7, Bild 1 von 2 Lenovo IdeaCentre AIO 510S-23ISU Arm Stand Replacement: Schritt 7, Bild 2 von 2
    • Lift up to remove the arm stand.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Jackson Blake
1.119 Reputation
9 Anleitungen geschrieben
Cal Poly, Team S16-G3, Banghart Winter 2018 Mitglied von Cal Poly, Team S16-G3, Banghart Winter 2018
CPSU-BANGHART-W18S16G3
4 Mitglieder
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 4
Letzte 7 Tage: 13
Letzte 30 Tage: 31
Insgesamt: 2,518
