Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Store
Einleitung
This part requires a phillips head screwdriver to remove the screws as well as a plastic spudger.
Ersatzteile
Keine Ersatzteile angegeben.
  1. Turn off the computer, unplug all cables, and let it cool down. Lay the computer flat on its screen.
    • Turn off the computer, unplug all cables, and let it cool down. Lay the computer flat on its screen.
    • Make sure that the work surface is flat and has nothing sharp on it.
  2. Remove the monitor stand screw in the bottom of the stand, and remove the stand completely. Remove the monitor stand screw in the bottom of the stand, and remove the stand completely.
    • Remove the monitor stand screw in the bottom of the stand, and remove the stand completely.
  3. Remove the two screws on the bottom of the computer, one on each side.
    • Remove the two screws on the bottom of the computer, one on each side.
  4. Locate the slot on the right side of the computer next to the screw hole. Use a plastic opening tool or spudger to pry off the rear cover. (Don’t be afraid to use a little force.) Locate the slot on the right side of the computer next to the screw hole. Use a plastic opening tool or spudger to pry off the rear cover. (Don’t be afraid to use a little force.) Locate the slot on the right side of the computer next to the screw hole. Use a plastic opening tool or spudger to pry off the rear cover. (Don’t be afraid to use a little force.)
    • Locate the slot on the right side of the computer next to the screw hole. Use a plastic opening tool or spudger to pry off the rear cover. (Don’t be afraid to use a little force.)
  5. Once it has been separated, lift to remove. Once it has been separated, lift to remove.
    • Once it has been separated, lift to remove.
Abschluss
Jackson Blake
1.062 Reputation
9 Anleitungen geschrieben
Cal Poly, Team S16-G3, Banghart Winter 2018 Mitglied von Cal Poly, Team S16-G3, Banghart Winter 2018
CPSU-BANGHART-W18S16G3
4 Mitglieder
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 0
Letzten 7 Tage: 8
Letzten 30 Tage: 47
Insgesamt: 1,583
