Zum Hauptinhalt wechseln
Lenovo IdeaCentre AIO 510S-23ISU Power Switch Board Replacement
Was du brauchst
  1. Lenovo IdeaCentre AIO 510S-23ISU Power Switch Board Replacement, Stand Base: Schritt 1, Bild 1 von 1
    • Turn off the computer, unplug all cables, and let it cool down. Lay the computer flat on its screen.
    • Make sure that the work surface is flat and has nothing sharp on it.
  2. Lenovo IdeaCentre AIO 510S-23ISU Power Switch Board Replacement: Schritt 2, Bild 1 von 2 Lenovo IdeaCentre AIO 510S-23ISU Power Switch Board Replacement: Schritt 2, Bild 2 von 2
    • Remove the monitor stand screw in the bottom of the stand, and remove the stand completely.
  3. Lenovo IdeaCentre AIO 510S-23ISU Power Switch Board Replacement, Back Cover: Schritt 3, Bild 1 von 1
    • Remove the two screws on the bottom of the computer, one on each side.
  4. Lenovo IdeaCentre AIO 510S-23ISU Power Switch Board Replacement: Schritt 4, Bild 1 von 3 Lenovo IdeaCentre AIO 510S-23ISU Power Switch Board Replacement: Schritt 4, Bild 2 von 3 Lenovo IdeaCentre AIO 510S-23ISU Power Switch Board Replacement: Schritt 4, Bild 3 von 3
    • Locate the slot on the right side of the computer next to the screw hole. Use a plastic opening tool or spudger to pry off the rear cover. (Don’t be afraid to use a little force.)
  5. Lenovo IdeaCentre AIO 510S-23ISU Power Switch Board Replacement: Schritt 5, Bild 1 von 2 Lenovo IdeaCentre AIO 510S-23ISU Power Switch Board Replacement: Schritt 5, Bild 2 von 2
    • Once it has been separated, lift to remove.
  6. Lenovo IdeaCentre AIO 510S-23ISU Power Switch Board Replacement, Arm Stand: Schritt 6, Bild 1 von 2 Lenovo IdeaCentre AIO 510S-23ISU Power Switch Board Replacement, Arm Stand: Schritt 6, Bild 2 von 2
    • Remove the four screws that secure the arm stand.
  7. Lenovo IdeaCentre AIO 510S-23ISU Power Switch Board Replacement: Schritt 7, Bild 1 von 2 Lenovo IdeaCentre AIO 510S-23ISU Power Switch Board Replacement: Schritt 7, Bild 2 von 2
    • Lift up to remove the arm stand.
  8. Lenovo IdeaCentre AIO 510S-23ISU Power Switch Board Replacement, EMI Cover: Schritt 8, Bild 1 von 3 Lenovo IdeaCentre AIO 510S-23ISU Power Switch Board Replacement, EMI Cover: Schritt 8, Bild 2 von 3 Lenovo IdeaCentre AIO 510S-23ISU Power Switch Board Replacement, EMI Cover: Schritt 8, Bild 3 von 3
    • Remove the 5 screws that secure the EMI cover.
    • Remove the cover.
  9. Lenovo IdeaCentre AIO 510S-23ISU Power Switch Board Replacement, Power Switch Board: Schritt 9, Bild 1 von 1
    • Locate the power switch board and the tan colored tab on it holding the blue and white ribbon cable down.
  10. Lenovo IdeaCentre AIO 510S-23ISU Power Switch Board Replacement: Schritt 10, Bild 1 von 1
    • Pull the tab towards the blue and white ribbon cable to open it. Pull the cable out of the power switch board.
  11. Lenovo IdeaCentre AIO 510S-23ISU Power Switch Board Replacement: Schritt 11, Bild 1 von 2 Lenovo IdeaCentre AIO 510S-23ISU Power Switch Board Replacement: Schritt 11, Bild 2 von 2
    • Slide the power switch cable out of its slot in the direction shown, making sure to lift up the end carefully.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Jackson Blake
1.119 Reputation
9 Anleitungen geschrieben
Cal Poly, Team S16-G3, Banghart Winter 2018 Mitglied von Cal Poly, Team S16-G3, Banghart Winter 2018
CPSU-BANGHART-W18S16G3
4 Mitglieder
Ein Kommentar
Hello
I have a similar problem on a Lenovo AiO 510-22ISH, how can i check if the power button board is really broken down?
After sales service said that was the problem but how can i test it?
Thank You
Fred - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 6
Insgesamt: 1,374
