Einleitung
This does not require any tools. However, be careful to align the notch in the bottom of the RAM module with the notch in the slot it goes in.
Was du brauchst
Turn off the computer, unplug all cables, and let it cool down. Lay the computer flat on its screen.
Remove the monitor stand screw in the bottom of the stand, and remove the stand completely.
Remove the two screws on the bottom of the computer, one on each side.
Locate the slot on the right side of the computer next to the screw hole. Use a plastic opening tool or spudger to pry off the rear cover. (Don’t be afraid to use a little force.)
Push the two retaining clips away from the RAM sticks.
Gently lift up the free side of the RAM module and then pull out of the slot.
6 weitere Nutzer:innen haben diese Anleitung absolviert.
