Ersatzteile
Kein Ersatzteil erforderlich.
  1. Lay the computer down on its side as shown.
    • Lay the computer down on its side as shown.
    • Remove the two 14mm screws shown. The screws are loose enough to unscrew with your hands.
  2. Gently slide the side panel straight back and remove from the computer.
    • Gently slide the side panel straight back and remove from the computer.
  3. Kostenloser Versand für alle Bestellungen über 100,00 $ oder mit einem Pro Tech Toolkit!
    Schau dich im Store um
    Schon mal was repariert? Genial!
    Teile ein Foto deiner Reparatur mit dem Hashtag #ImAGenius
    Wir sind alle Genies
  4. Using the Phillips #00 Precision screwdriver, unscrew the four 12mm screws that hold the fan in place.
    • Using the Phillips #00 Precision screwdriver, unscrew the four 12mm screws that hold the fan in place.
    • Be careful not to strip the screws.
  5. Unplug the fan from the motherboard by gently pulling out the single plug. Then lift the fan up and out of the computer.
    • Unplug the fan from the motherboard by gently pulling out the single plug. Then lift the fan up and out of the computer.
  6. Loosen the four screws that hold the heat sink in place using a Phillips #2 screwdriver.
    • Loosen the four screws that hold the heat sink in place using a Phillips #2 screwdriver.
    • The screws do not come all the way out of the heat sink
    • Pull the heat sink straight up to remove it.
Abschluss
Timothy Grebe
1.319 Reputation
9 Anleitungen geschrieben
Cal Poly, Team 10-39, Amido Fall 2014 Mitglied von Cal Poly, Team 10-39, Amido Fall 2014
CPSU-AMIDO-F14S10G39
4 Mitglieder
Statistik anzeigen:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 2
Insgesamt: 408
