Was du brauchst
Lay the computer down on its side as shown.
Remove the two 14mm screws shown. The screws are loose enough to unscrew with your hands.
Pull up on the three tabs shown
Swivel the front panel so the front is open, and gently pull the cover off
Push down on the button that says "push" while pulling the optical drive outward.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
