Was du brauchst
Lay the computer down on its side as shown.
Remove the two 14mm screws shown. The screws are loose enough to unscrew with your hands.
Unplug both sets of wires attaching the power supply unit to the motherboard.
Using the Phillips #2 driver, unscrew the four 8mm screws attaching the power supply unit to the outside of the computer.
9 weitere Nutzer:innen haben diese Anleitung absolviert.
Ein Kommentar
What part do I need to replace the POWER BUTTON, it's broke and have to press inside to power on?
