Zum Hauptinhalt wechseln
Lenovo IdeaCentre K410 RAM Module Replacement
Was du brauchst
  1. Lenovo IdeaCentre K410 RAM Module Replacement, Side Panel: Schritt 1, Bild 1 von 1
    • Lay the computer down on its side as shown.
    • Remove the two 14mm screws shown. The screws are loose enough to unscrew with your hands.
  2. Lenovo IdeaCentre K410 RAM Module Replacement: Schritt 2, Bild 1 von 1
    • Gently slide the side panel straight back and remove from the computer.
  3. Lenovo IdeaCentre K410 RAM Module Replacement, RAM Module: Schritt 3, Bild 1 von 1
    • Push down on the white clips on both sides of the memory module to release it.
    • Gently pull up on the memory module to remove it from the unit.
Abschluss
When inserting the memory module, make sure that the notch on it aligns correctly with the key on the memory connector. Push the module straight down into the connector until the retaining clips close.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
Timothy Grebe
1.634 Reputation
9 Anleitungen geschrieben
Cal Poly, Team 10-39, Amido Fall 2014 Mitglied von Cal Poly, Team 10-39, Amido Fall 2014
CPSU-AMIDO-F14S10G39
4 Mitglieder
18 Anleitungen geschrieben
2 Kommentare
sounds very hard to replace a ram “sarcastically“
you probley can replace a ram if you know what ram is so
remliv - Antwort
But it is still good to have guides on everything
im glad that ifixit exists
remliv - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 15
Insgesamt: 1,440
