Was du brauchst
Lay the computer down on its side as shown.
Remove the two 14mm screws shown. The screws are loose enough to unscrew with your hands.
With your hands remove the 14mm screw that holds the cover on the back panel.
Gently pull the flap back to expose the expansion card retaining screw.
Use the Phillips #2 to remove the 8mm screw that holds the USB 3.0 Expansion Card in place.
With moderate force, pull straight up on the expansion card to remove it from the computer.
3 weitere Nutzer:innen haben diese Anleitung absolviert.
Ein Kommentar
Why is a USB 3.1 Gen 1 adapter card called TV Tuner? It is an adapter card. What you connect to it is irelevant.
