Zum Hauptinhalt wechseln
Lenovo IdeaCentre K410 USB 3.0 Expansion Card Replacement
Was du brauchst
  1. Lenovo IdeaCentre K410 USB 3.0 Expansion Card Replacement, Side Panel: Schritt 1, Bild 1 von 1
    • Lay the computer down on its side as shown.
    • Remove the two 14mm screws shown. The screws are loose enough to unscrew with your hands.
  2. Lenovo IdeaCentre K410 USB 3.0 Expansion Card Replacement: Schritt 2, Bild 1 von 1
    • Gently slide the side panel straight back and remove from the computer.
  3. Lenovo IdeaCentre K410 USB 3.0 Expansion Card Replacement, USB 3.0 Expansion Card: Schritt 3, Bild 1 von 1
    • With your hands remove the 14mm screw that holds the cover on the back panel.
    • Gently pull the flap back to expose the expansion card retaining screw.
  4. Lenovo IdeaCentre K410 USB 3.0 Expansion Card Replacement: Schritt 4, Bild 1 von 1
    • Use the Phillips #2 to remove the 8mm screw that holds the USB 3.0 Expansion Card in place.
  5. Lenovo IdeaCentre K410 USB 3.0 Expansion Card Replacement: Schritt 5, Bild 1 von 1
    • With moderate force, pull straight up on the expansion card to remove it from the computer.
Abschluss
3 weitere Nutzer:innen haben diese Anleitung absolviert.
Timothy Grebe
1.634 Reputation
9 Anleitungen geschrieben
Cal Poly, Team 10-39, Amido Fall 2014 Mitglied von Cal Poly, Team 10-39, Amido Fall 2014
CPSU-AMIDO-F14S10G39
4 Mitglieder
18 Anleitungen geschrieben
Ein Kommentar
Why is a USB 3.1 Gen 1 adapter card called TV Tuner? It is an adapter card. What you connect to it is irelevant.
TheLOD2010 - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 11
Letzte 30 Tage: 21
Insgesamt: 1,128
