Einleitung
This guide will help the users fix issues with the speakers found in the Lenovo IdeaPad 100S-141BR.
Was du brauchst
For safety reasons, disconnect the wires connecting the battery to the motherboard with the nylon spudger.
Remove the six 4mm Phillips #00 screws.
Remove the battery using the nylon spudger.
Remove the four 2mm PH00 screws.
Unplug the speakers from the motherboard.
Remove the two 4mm PH00 screws from the metal shield on the trackpad.
Lift the metal shield up slightly, being very careful not to move the ribbon cables too much. Move the speaker cables out from under the shield.
Lift the speakers from the case being careful of the wires connecting them. Put them to the side.
