Zum Hauptinhalt wechseln
Lenovo IdeaPad 110 Touch-15ACL Battery Replacement
Was du brauchst
  1. Lenovo IdeaPad 110 Touch-15ACL Battery Replacement, Back Case: Schritt 1, Bild 1 von 1
    • Remove the thirteen 6 mm Phillips #0 screws.
  2. Lenovo IdeaPad 110 Touch-15ACL Battery Replacement: Schritt 2, Bild 1 von 2 Lenovo IdeaPad 110 Touch-15ACL Battery Replacement: Schritt 2, Bild 2 von 2
    • Use an opening tool to gently disconnect most of the clips on the back panel.
    • DO NOT force the panel out towards the optical disk drive.
  3. Lenovo IdeaPad 110 Touch-15ACL Battery Replacement: Schritt 3, Bild 1 von 3 Lenovo IdeaPad 110 Touch-15ACL Battery Replacement: Schritt 3, Bild 2 von 3 Lenovo IdeaPad 110 Touch-15ACL Battery Replacement: Schritt 3, Bild 3 von 3
    • Pry the disk drive away from the center of the laptop.
    • Don't worry about any screws since we already removed the screws that are associated with the drive.
    • Once the drive is removed, remove the one 2 mm Phillips #0 screw that is now exposed.
  4. Lenovo IdeaPad 110 Touch-15ACL Battery Replacement: Schritt 4, Bild 1 von 3 Lenovo IdeaPad 110 Touch-15ACL Battery Replacement: Schritt 4, Bild 2 von 3 Lenovo IdeaPad 110 Touch-15ACL Battery Replacement: Schritt 4, Bild 3 von 3
    • Unclip any of the remaining clips and remove the back panel.
  5. Lenovo IdeaPad 110 Touch-15ACL Battery Replacement, Battery Replacement: Schritt 5, Bild 1 von 1
    • Remove the four 6 mm Phillips #0 mounting screws.
  6. Lenovo IdeaPad 110 Touch-15ACL Battery Replacement: Schritt 6, Bild 1 von 3 Lenovo IdeaPad 110 Touch-15ACL Battery Replacement: Schritt 6, Bild 2 von 3 Lenovo IdeaPad 110 Touch-15ACL Battery Replacement: Schritt 6, Bild 3 von 3
    • Detach the wire connected to the motherboard and remove the battery assembly.
Abschluss
Addie
88 Reputation
1 Anleitung geschrieben
Clemson, Team 2-3, Hunter Spring 2022 Mitglied von Clemson, Team 2-3, Hunter Spring 2022
CLEM-HUNTER-S22S2G3
5 Mitglieder
6 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 3
Letzte 30 Tage: 12
Insgesamt: 468
