Einleitung
This guide shows how to replace the screen on the Lenovo IdeaPad 110-15IBR. The steps show the process of removing the protective cover from the front of the screen, unscrewing the screws holding the screen in place, and unhooking the cable attaching the screen to the device.
Was du brauchst
Using a plastic opening tool, gently pry the cover off of the display.
Lay screen flat down to remove the tabs from each corner.
Using the #1 Phillips head screwdriver unscrew the 4 (9mmx6mm) screws holding the screen in place.
Remove the tape holding the connected wire to the display.
Gently remove the display wire from the connection.
Remove the display from the device.
13 weitere Personen haben diese Anleitung absolviert.
