Zum Hauptinhalt wechseln
Lenovo IdeaPad 110-15IBR Hard Drive Replacement
Was du brauchst
  1. Lenovo IdeaPad 110-15IBR Hard Drive Replacement, keyboard: Schritt 1, Bild 1 von 2 Lenovo IdeaPad 110-15IBR Hard Drive Replacement, keyboard: Schritt 1, Bild 2 von 2
    • Before you proceed, make sure your computer is turned off and it's not connected to any power source. Before removing the drive, make a backup copy of all the information on it if possible. Never remove the drive while the system is operating or in suspend mode.
    • Place laptop with the bottom facing up. Using a Philip #1 screwdriver unscrew all 13 screws. Gently pry the back out using a plastic opening tool, starting from one of the corners.
    Frag FixBot
    Kommentar hinzufügen
  2. Lenovo IdeaPad 110-15IBR Hard Drive Replacement: Schritt 2, Bild 1 von 1
    • Using a Phillips #1 screwdriver, remove the four (5mm) screws holding the hard drive in place.
    Frag FixBot
  3. Lenovo IdeaPad 110-15IBR Hard Drive Replacement: Schritt 3, Bild 1 von 2 Lenovo IdeaPad 110-15IBR Hard Drive Replacement: Schritt 3, Bild 2 von 2
    • Do not lift hard drive straight up otherwise you might risk breaking the connection port.
    • Gently slide the hard drive away and out out of the connection port.
    Frag FixBot
  4. Lenovo IdeaPad 110-15IBR Hard Drive Replacement: Schritt 4, Bild 1 von 2 Lenovo IdeaPad 110-15IBR Hard Drive Replacement: Schritt 4, Bild 2 von 2
    • Using a Philip #1 screwdriver remove 2 screws from each side, (removing 4 screws in total) holding the hard drive into the housing.
    Frag FixBot
  5. Lenovo IdeaPad 110-15IBR Hard Drive Replacement: Schritt 5, Bild 1 von 1
    • Remove hard drive from housing.
    Frag FixBot
Abschluss
To reassemble your device, follow these instructions in reverse order with your new replacement hard drive.
15 weitere Personen haben diese Anleitung absolviert.
UW Tacoma, Team S3-G4, Liner Fall 2017 Mitglied von UW Tacoma, Team S3-G4, Liner Fall 2017
UWT-LINER-F17S3G4
4 Mitglieder
14 Anleitungen geschrieben
4 Kommentare zur Anleitung
Unplug or remove battery first?
Chris Quirke - Antwort Teilen
Hard disk size?
Mohamad Mustakim - Antwort Teilen
you do not need to unplug or remove the battery
Holden Phillips - Antwort Teilen
guys how do i open hard disk?
SHAHRIYOR ZOYIRQULOV - Antwort Teilen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 10
Letzte 30 Tage: 56
Insgesamt: 21,054
