Einleitung
If the Lenovo has a blue screen appear, overheats, or locks up or freezes, then there may be a faulty motherboard. To replace the motherboard, follow the guide provided to replace it.
Was du brauchst
Flip the IdeaPad bottom side up.
Using a Phillips #1 screwdriver, remove the two 6.0mm screws on the back panel, that hold the keyboard.
Flip the computer back to top facing.
Open the lid.
Use the plastic opening tool to pry the keyboard up and away from the bottom assembly.
Next disconnect the keyboard cable by using the tip of the spudger or your finger to lightly push out the ribbon from the contact port.
Completely remove the keyboard from the bottom assembly.
Using a Phillips #1 screwdriver, unscrew the one 5.0mm screw on the back panel.
Flip the laptop to its back and the optical drive is located at the top left corner.
Remove the optical CD DVD drive by lightly pulling it out of the assembly.
Place the laptop bottom facing up.
Using a Phillips #1 screwdriver, remove the remaining eight 6.0mm screws on the back panel.
Separate the top case from the bottom using a plastic opening tool.
Continue prying the top and bottom case from each other all around the perimeter of the laptop.
Pull the two connectors with blue ribbons marked with MB in the opposite direction of the connector
Using a Phillips #1 screwdriver, remove the marked four 4.0mm screws.
Pull out the hard drive.
Using tweezers, pull the four marked connectors out and away from the motherboard.
Remove the WIFI card by pulling up and away from the motherboard.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
