Zum Hauptinhalt wechseln
Lenovo IdeaPad 110-171KB Battery Replacement
Was du brauchst
  1. Lenovo IdeaPad 110-171KB Battery Replacement, Battery: Schritt 1, Bild 1 von 2 Lenovo IdeaPad 110-171KB Battery Replacement, Battery: Schritt 1, Bild 2 von 2
    • Insert an opening pick between the chassis and keyboard.
    • Gently slide the pick around the perimeter of the keyboard while prying until it releases completely.
    • Remove the keyboard.
  2. Lenovo IdeaPad 110-171KB Battery Replacement: Schritt 2, Bild 1 von 2 Lenovo IdeaPad 110-171KB Battery Replacement: Schritt 2, Bild 2 von 2
    • Disconnect the cable connector from the motherboard.
    • Slide the cable out of the case.
  3. Lenovo IdeaPad 110-171KB Battery Replacement: Schritt 3, Bild 1 von 1
    • Place the the computer bottom facing up. Unscrew the eleven Phillips #0 6 mm screws.
  4. Lenovo IdeaPad 110-171KB Battery Replacement: Schritt 4, Bild 1 von 2 Lenovo IdeaPad 110-171KB Battery Replacement: Schritt 4, Bild 2 von 2
    • Pry the disk drive opposite of the laptop.
    • Since the screws has already been removed, you will not need to worry about any more screws on the optical drive.
  5. Lenovo IdeaPad 110-171KB Battery Replacement: Schritt 5, Bild 1 von 2 Lenovo IdeaPad 110-171KB Battery Replacement: Schritt 5, Bild 2 von 2
    • Release any of the remaining retaining clips and remove the lower case.
  6. Lenovo IdeaPad 110-171KB Battery Replacement: Schritt 6, Bild 1 von 3 Lenovo IdeaPad 110-171KB Battery Replacement: Schritt 6, Bild 2 von 3 Lenovo IdeaPad 110-171KB Battery Replacement: Schritt 6, Bild 3 von 3
    • Remove the two 9 mm Phillips #0 screws that secure the battery.
    • Remove the battery from the device.
Abschluss
Cameron Mounce
668 Reputation
5 Anleitungen geschrieben
Gateway, Team 1-3, Pee Fall 2023 Mitglied von Gateway, Team 1-3, Pee Fall 2023
GCC-PEE-F23S1G3
4 Mitglieder
7 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 3
Letzte 30 Tage: 6
Insgesamt: 93
