Zum Hauptinhalt wechseln
Lenovo IdeaPad 110-17IKB Fan Replacement
Was du brauchst
  1. Lenovo IdeaPad 110-17IKB Fan Replacement, Lower Case: Schritt 1, Bild 1 von 1
    • First, before you do anything, make sure the computer has been turned off and unplugged.
    • Place the the computer bottom facing up. Unscrew the eleven 6 mm screws using a Phillips #0 screwdriver.
  2. Lenovo IdeaPad 110-17IKB Fan Replacement: Schritt 2, Bild 1 von 2 Lenovo IdeaPad 110-17IKB Fan Replacement: Schritt 2, Bild 2 von 2
    • Use an opening tool to gently disconnect the clips on the side of the back panel.
    • DO NOT try to force open the panel, as this may cause damage to it.
  3. Lenovo IdeaPad 110-17IKB Fan Replacement: Schritt 3, Bild 1 von 2 Lenovo IdeaPad 110-17IKB Fan Replacement: Schritt 3, Bild 2 von 2
    • Pry out the optical drive opposite of the laptop.
    • Since the screws have already been removed, you will not need to worry about any more screws on the optical drive.
  4. Lenovo IdeaPad 110-17IKB Fan Replacement: Schritt 4, Bild 1 von 3 Lenovo IdeaPad 110-17IKB Fan Replacement: Schritt 4, Bild 2 von 3 Lenovo IdeaPad 110-17IKB Fan Replacement: Schritt 4, Bild 3 von 3
    • Release the remaining clasp and remove the lower case.
  5. Lenovo IdeaPad 110-17IKB Fan Replacement, Fan: Schritt 5, Bild 1 von 2 Lenovo IdeaPad 110-17IKB Fan Replacement, Fan: Schritt 5, Bild 2 von 2
    In diesem Schritt verwendetes Werkzeug:
    Kaufen
    • Unscrew the four 6 mm Phillips #0 screws that secure the fan.
    • Push the white fan connector directly out of its port using tweezers or a pry tool.
    • Lift the fan up and out of the chassis.
Abschluss
Cameron Mounce
668 Reputation
5 Anleitungen geschrieben
Gateway, Team 1-3, Pee Fall 2023 Mitglied von Gateway, Team 1-3, Pee Fall 2023
GCC-PEE-F23S1G3
4 Mitglieder
7 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 15
Insgesamt: 55
