Zum Hauptinhalt wechseln
Lenovo IdeaPad 3-1481W000NGUS Wi-Fi Card Replacement
Was du brauchst
  1. Lenovo IdeaPad 3-1481W000NGUS Wi-Fi Card Replacement, Back Cover: Schritt 1, Bild 1 von 3 Lenovo IdeaPad 3-1481W000NGUS Wi-Fi Card Replacement, Back Cover: Schritt 1, Bild 2 von 3 Lenovo IdeaPad 3-1481W000NGUS Wi-Fi Card Replacement, Back Cover: Schritt 1, Bild 3 von 3
    In diesem Schritt verwendetes Werkzeug:
    Magnetic Project Mat
    $19.95
    Kaufen
    • Orient the laptop so that the bottom is facing up.
    • Remove the six 7 mm screws using a Phillips #00 screwdriver.
    • Remove the four 4 mm screws using a Phillips #00 screwdriver.
  2. Lenovo IdeaPad 3-1481W000NGUS Wi-Fi Card Replacement: Schritt 2, Bild 1 von 3 Lenovo IdeaPad 3-1481W000NGUS Wi-Fi Card Replacement: Schritt 2, Bild 2 von 3 Lenovo IdeaPad 3-1481W000NGUS Wi-Fi Card Replacement: Schritt 2, Bild 3 von 3
    • Pry up the sides of the back case using the iFixit opening tool. Then, lift to remove.
    • You may hear snapping when removing the panel. This is normal!
  3. Lenovo IdeaPad 3-1481W000NGUS Wi-Fi Card Replacement, Wi-Fi Card: Schritt 3, Bild 1 von 2 Lenovo IdeaPad 3-1481W000NGUS Wi-Fi Card Replacement, Wi-Fi Card: Schritt 3, Bild 2 von 2
    • Use your fingernail or an opening tool to gently pull out and disconnect the battery pack cable.
    • Do not pull on the cables.
  4. Lenovo IdeaPad 3-1481W000NGUS Wi-Fi Card Replacement: Schritt 4, Bild 1 von 2 Lenovo IdeaPad 3-1481W000NGUS Wi-Fi Card Replacement: Schritt 4, Bild 2 von 2
    • Use the spudger to remove each cable from the Wi-Fi card, one cable at a time.
    • The cables do not need much force to be removed.
  5. Lenovo IdeaPad 3-1481W000NGUS Wi-Fi Card Replacement: Schritt 5, Bild 1 von 3 Lenovo IdeaPad 3-1481W000NGUS Wi-Fi Card Replacement: Schritt 5, Bild 2 von 3 Lenovo IdeaPad 3-1481W000NGUS Wi-Fi Card Replacement: Schritt 5, Bild 3 von 3
    • Remove the single 2 mm screw using a Phillips #00 screwdriver.
    • Try not to press to hard down on the computer to avoid damage.
  6. Lenovo IdeaPad 3-1481W000NGUS Wi-Fi Card Replacement: Schritt 6, Bild 1 von 3 Lenovo IdeaPad 3-1481W000NGUS Wi-Fi Card Replacement: Schritt 6, Bild 2 von 3 Lenovo IdeaPad 3-1481W000NGUS Wi-Fi Card Replacement: Schritt 6, Bild 3 von 3
    • Pull the card away from the housing capsule on the right side of the Wi-Fi card to remove it from the laptop.
    • Make sure no cables are still connected or wrapped around the Wi-Fi card when removing.
Abschluss
William Hart
109 Reputation
1 Anleitung geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 19
Letzte 30 Tage: 39
Insgesamt: 201
