Einleitung
Use this guide to replace the battery in the Lenovo IdeaPad 3-14IIL05 laptop.
The battery supplies the laptop with power. It is usually the first thing that fails in a laptop. If the device does not hold a charge or does not turn on, it is smart to check the battery first.
Was du brauchst
Flip the laptop with the screen side facing down and the back panel facing you.
Remove the six 1.2 mm screws and the four 0.6 mm screws using a Phillips #1 screwdriver.
Remove the screws holding down the battery.
Unplug the battery from the motherboard.
Remove the battery from the laptop.
Eine weitere Person hat diese Anleitung absolviert.
