Einleitung
Use this guide to replace the daughterboard in the Lenovo IdeaPad 3-14IIL05 laptop..
Was du brauchst
Flip the laptop with the screen side facing down and the back panel facing you.
Remove the six 1.2 mm screws and the four 0.6 mm screws using a Phillips #1 screwdriver.
Remove the four screws from the daughterboard.
Lift up the L-shaped bracket.
Unplug the ribbon cable from the daughterboard by flipping the clamp up.
Remove the daughterboard.
Abschluss
