Zum Hauptinhalt wechseln
Lenovo IdeaPad 3-15ADA05 Heat Sink Replacement
Was du brauchst
  1. Lenovo IdeaPad 3-15ADA05 Heat Sink Replacement, Heat Sink: Schritt 1, Bild 1 von 2 Lenovo IdeaPad 3-15ADA05 Heat Sink Replacement, Heat Sink: Schritt 1, Bild 2 von 2
    • Remove the six M2 x 5mm screws located at the top half of the laptop using a #0 Phillips head, then remove the four M2 x 2.5mm screws located at the bottom of the laptop using a #0 Phillips head.
  2. Lenovo IdeaPad 3-15ADA05 Heat Sink Replacement: Schritt 2, Bild 1 von 2 Lenovo IdeaPad 3-15ADA05 Heat Sink Replacement: Schritt 2, Bild 2 von 2
    • Insert the opening pick between the base plate and the bottom of the laptop, and pry the clips loose around the edge until the base pops off.
  3. Lenovo IdeaPad 3-15ADA05 Heat Sink Replacement: Schritt 3, Bild 1 von 3 Lenovo IdeaPad 3-15ADA05 Heat Sink Replacement: Schritt 3, Bild 2 von 3 Lenovo IdeaPad 3-15ADA05 Heat Sink Replacement: Schritt 3, Bild 3 von 3
    • Locate the heat sink above the fan, then using a #0 Phillips head, remove the four M2 x 3mm screws holding the heat sink in place.
    • The screws are captive and should stay attached to the heat sink.
  4. Lenovo IdeaPad 3-15ADA05 Heat Sink Replacement: Schritt 4, Bild 1 von 2 Lenovo IdeaPad 3-15ADA05 Heat Sink Replacement: Schritt 4, Bild 2 von 2
    • Remove the heat sink.
    • Be careful not to damage the processor.
  5. Lenovo IdeaPad 3-15ADA05 Heat Sink Replacement: Schritt 5, Bild 1 von 2 Lenovo IdeaPad 3-15ADA05 Heat Sink Replacement: Schritt 5, Bild 2 von 2
    • Using a paper towel and rubbing alcohol. Apply a small amount to the paper towel, then remove the remaining thermal paste until none is left.
  6. Lenovo IdeaPad 3-15ADA05 Heat Sink Replacement: Schritt 6, Bild 1 von 3 Lenovo IdeaPad 3-15ADA05 Heat Sink Replacement: Schritt 6, Bild 2 von 3 Lenovo IdeaPad 3-15ADA05 Heat Sink Replacement: Schritt 6, Bild 3 von 3
    • Evenly apply a very small amount of thermal paste to the processor (around the size of a grain of rice), then replace the new Heat sink and press down gently.
    • Be careful when reattaching the cooler so as not to damage the processor.
    • Tighten the screws in a diagonal pattern to ensure even pressure and spread of the thermal paste.
Abschluss
Dylan Torres
133 Reputation
1 Anleitung geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 21
Insgesamt: 58
