Zum Hauptinhalt wechseln
Lenovo IdeaPad 3-15IGL05 SSD Replacement
Was du brauchst
  1. Lenovo IdeaPad 3-15IGL05 SSD Replacement, SSD: Schritt 1, Bild 1 von 1
    • Use a Phillips #0 screwdriver to remove the ten 7.6 mm screws securing the bottom panel.
  2. Lenovo IdeaPad 3-15IGL05 SSD Replacement: Schritt 2, Bild 1 von 2 Lenovo IdeaPad 3-15IGL05 SSD Replacement: Schritt 2, Bild 2 von 2
    • Wedge an opening tool in the gap between the bottom panel and chassis, and pry vertically around the perimeter until you hear a "pop" and the panel releases.
    • Lift the bottom panel up and off the chassis.
  3. Lenovo IdeaPad 3-15IGL05 SSD Replacement: Schritt 3, Bild 1 von 2 Lenovo IdeaPad 3-15IGL05 SSD Replacement: Schritt 3, Bild 2 von 2
    • Locate the SSD at the bottom right corner of the fan.
    • Use a Phillips #000 screwdriver to remove the single 3 mm screw securing the SSD.
    • The drive should slightly lift once the screw is removed.
  4. Lenovo IdeaPad 3-15IGL05 SSD Replacement: Schritt 4, Bild 1 von 1
    • Gently pull the SSD directly out of its port.
    • Do not over-tighten the screws during reassembly.
Abschluss
Matthew Frederic
109 Reputation
1 Anleitung geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 12
Letzte 30 Tage: 104
Insgesamt: 3,411
