Zum Hauptinhalt wechseln
Lenovo IdeaPad 3-15IML05 Fan Replacement
Was du brauchst
  1. Lenovo IdeaPad 3-15IML05 Fan Replacement, Lower Case: Schritt 1, Bild 1 von 2 Lenovo IdeaPad 3-15IML05 Fan Replacement, Lower Case: Schritt 1, Bild 2 von 2
    • Before beginning, discharge the battery below 25%, power the device off, and disconnect all peripherals.
    • Use a Phillips #1 screwdriver to remove the following screws:
    • Six 7 mm screws
    • Four 4 mm screws
  2. Lenovo IdeaPad 3-15IML05 Fan Replacement: Schritt 2, Bild 1 von 2 Lenovo IdeaPad 3-15IML05 Fan Replacement: Schritt 2, Bild 2 von 2
    • Insert an opening pick into the seam between the lower case and chassis.
    • Slide the pick around the entire perimeter until all of the plastic retaining clips release.
    • Remove the lower case.
    • Forcing the back cover open could break the plastic retaining clips.
    • During reassembly, lay the cover flat and press around the edges to secure it to the plastic clips.
  3. Lenovo IdeaPad 3-15IML05 Fan Replacement, Lenovo IdeaPad 3-15IML05 Battery Disconnection: Schritt 3, Bild 1 von 2 Lenovo IdeaPad 3-15IML05 Fan Replacement, Lenovo IdeaPad 3-15IML05 Battery Disconnection: Schritt 3, Bild 2 von 2
    • Use a plastic spudger or your fingernail to gently push the JST battery connector out of its socket.
    • Pulling directly on the cable could damage the connector.
  4. Lenovo IdeaPad 3-15IML05 Fan Replacement, Fan: Schritt 4, Bild 1 von 2 Lenovo IdeaPad 3-15IML05 Fan Replacement, Fan: Schritt 4, Bild 2 von 2
    • Use a Phillips screwdriver to remove the three screws securing the fan to the chassis.
  5. Lenovo IdeaPad 3-15IML05 Fan Replacement: Schritt 5, Bild 1 von 2 Lenovo IdeaPad 3-15IML05 Fan Replacement: Schritt 5, Bild 2 von 2
    • Grip the tab at the end of the bundle cable and pull the connector slowly and steadily out of its socket to disconnect the fan cable.
    • Be careful that you do not damage the socket on the motherboard when disconnecting the fan cable.
    • Disconnect the fan from the heat sink.
    • Gently unhook the black wire from the tabs around the edge of the fan.
    • Lift the fan from the laptop to remove it.
    • If there is any resistance, double-check that the screws and connections have been removed
Abschluss
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
Collin
419 Reputation
2 Anleitungen geschrieben
UMass Dartmouth, Team 2-2, Santin Fall 2024 Mitglied von UMass Dartmouth, Team 2-2, Santin Fall 2024
UMASSD-SANTIN-F24S2G2
4 Mitglieder
3 Anleitungen geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 26
Insgesamt: 287
