Zum Hauptinhalt wechseln
Lenovo IdeaPad 300-17ISK Optical Drive Replacement
Was du brauchst
  1. Lenovo IdeaPad 300-17ISK Optical Drive Replacement, Keyboard: Schritt 1, Bild 1 von 1
    • Unscrew the three 6mm Phillips #1 screws from the upper back cover.
  2. Lenovo IdeaPad 300-17ISK Optical Drive Replacement: Schritt 2, Bild 1 von 3 Lenovo IdeaPad 300-17ISK Optical Drive Replacement: Schritt 2, Bild 2 von 3 Lenovo IdeaPad 300-17ISK Optical Drive Replacement: Schritt 2, Bild 3 von 3
    • Place the opening tool's head under any edge of the keyboard.
    • Pull upwards to unsnap the keyboard.
    • Use your fingers and the opening tool to pop the keyboard out of its place.
    • You should't use any excessive force because the keyboard is still attached to the motherboard.
  3. Lenovo IdeaPad 300-17ISK Optical Drive Replacement: Schritt 3, Bild 1 von 2 Lenovo IdeaPad 300-17ISK Optical Drive Replacement: Schritt 3, Bild 2 von 2
    • Push the keyboard connector latch upwards with the spudger.
    • You shouldn't use excessive force. The connector latch is very fragile.
    • The keyboard connector cable should slide right out.
  4. Lenovo IdeaPad 300-17ISK Optical Drive Replacement, Optical Drive: Schritt 4, Bild 1 von 1
    • Remove the 6mm Phillips #1 screw that sits in the center of the front plate below the keyboard. This screw sits between two adjacent tabbed holes.
  5. Lenovo IdeaPad 300-17ISK Optical Drive Replacement: Schritt 5, Bild 1 von 3 Lenovo IdeaPad 300-17ISK Optical Drive Replacement: Schritt 5, Bild 2 von 3 Lenovo IdeaPad 300-17ISK Optical Drive Replacement: Schritt 5, Bild 3 von 3
    • Insert the opening tool's head into one of the tabbed holes.
    • With the opening tool's head inserted under a tab, push to the right. The optical drive should slide out easily.
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
Ammar Dodin
1.057 Reputation
6 Anleitungen geschrieben
UC Davis, Team 1-3, Rodger Winter 2017 Mitglied von UC Davis, Team 1-3, Rodger Winter 2017
UCD-RODGER-W17S1G3
4 Mitglieder
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 7
Letzte 30 Tage: 34
Insgesamt: 5,120
