Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Werkzeug & Ersatzteile
Ersatzteile
Keine Ersatzteile angegeben.
  1. Flip laptop over and remove 13 screws from the bottom panel. Remove RAM panel after removing 3 screws.
    • Flip laptop over and remove 13 screws from the bottom panel.
    • Remove RAM panel after removing 3 screws.
  2. Disconnect keyboard and touchpad wire. Remove CD port.
    • Disconnect keyboard and touchpad wire.
    • Remove CD port.
  3. Nintendo Switch Kits
    A quick fix to get back in the game
    Shop Switch Kits
    Shop Switch Kits
  4. Flip laptop back over. Using a plastic spudger, pry between the keyboard panel and bottom panel on all 4 sides.
    • Flip laptop back over.
    • Using a plastic spudger, pry between the keyboard panel and bottom panel on all 4 sides.
  5. Remove the 5 screws and 4 tabs holding the motherboard and remove. Before removing motherboard, be sure to disconnect the fan tab on the bottom. Before removing motherboard, be sure to disconnect the fan tab on the bottom.
    • Remove the 5 screws and 4 tabs holding the motherboard and remove.
    • Before removing motherboard, be sure to disconnect the fan tab on the bottom.
  6. Unscrew the 2 screws and 1 pull tab holding the battery in place. Carefully remove battery.
    • Unscrew the 2 screws and 1 pull tab holding the battery in place.
    • Carefully remove battery.
Abschluss
Ein weiterer Nutzer hat diese Anleitung absolviert.
Cam Plute
153 Reputation
1 Anleitung geschrieben
Washington State, Team S5-G7, Phelps-Hillen Fall 2017 Mitglied von Washington State, Team S5-G7, Phelps-Hillen Fall 2017
WSU-PHELPS-HILLEN-F17S5G7
4 Mitglieder
8 Anleitungen geschrieben
Step 2 should include removing connectors for the wireless card.
Ronn Richardson - Antwort
Thanks for your commentary, I have added this in my French translation but I don’t know why I can’t modify the tutorial in English.. Maybe because I am a French member..
Zacharie Troletti-Gillot -
The fan should also be disconnected in step 2 not step 4.
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 16
Letzten 7 Tage: 115
Letzten 30 Tage: 391
Insgesamt: 10,838
