Zum Hauptinhalt wechseln
Lenovo IdeaPad 330-15ARR Wi-Fi Card Replacement
Was du brauchst
  1. Lenovo IdeaPad 330-15ARR Wi-Fi Card Replacement, Lower Case: Schritt 1, Bild 1 von 1
    • Remove all Phillips #0 screws securing the case to the laptop.
  2. Lenovo IdeaPad 330-15ARR Wi-Fi Card Replacement: Schritt 2, Bild 1 von 2 Lenovo IdeaPad 330-15ARR Wi-Fi Card Replacement: Schritt 2, Bild 2 von 2
    • Pry all edges off of the laptop with the opening tool until the lower case releases.
    • Remove the lower case.
  3. Lenovo IdeaPad 330-15ARR Wi-Fi Card Replacement, Wi-Fi Card: Schritt 3, Bild 1 von 3 Lenovo IdeaPad 330-15ARR Wi-Fi Card Replacement, Wi-Fi Card: Schritt 3, Bild 2 von 3 Lenovo IdeaPad 330-15ARR Wi-Fi Card Replacement, Wi-Fi Card: Schritt 3, Bild 3 von 3
    • Remove the two Wi-Fi card's connections by gently lifting up on the connectors.
  4. Lenovo IdeaPad 330-15ARR Wi-Fi Card Replacement: Schritt 4, Bild 1 von 3 Lenovo IdeaPad 330-15ARR Wi-Fi Card Replacement: Schritt 4, Bild 2 von 3 Lenovo IdeaPad 330-15ARR Wi-Fi Card Replacement: Schritt 4, Bild 3 von 3
    • Remove the single Phillips #0 screw securing the Wi-Fi card.
  5. Lenovo IdeaPad 330-15ARR Wi-Fi Card Replacement: Schritt 5, Bild 1 von 2 Lenovo IdeaPad 330-15ARR Wi-Fi Card Replacement: Schritt 5, Bild 2 von 2
    • Slide the Wi-Fi card out of its port on the motherboard.
    • Do not worry about the angle the card sits after removing the mounting screw - this is how it's meant to be connected and will have to be connected similarly during reassembly.
Abschluss
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 2
Letzte 30 Tage: 16
Insgesamt: 562
