Zum Hauptinhalt wechseln
Lenovo IdeaPad 330-15IKB 81DE Speaker Replacement
Was du brauchst
  1. Lenovo IdeaPad 330-15IKB 81DE Speaker Replacement, Back Panel: Schritt 1, Bild 1 von 3 Lenovo IdeaPad 330-15IKB 81DE Speaker Replacement, Back Panel: Schritt 1, Bild 2 von 3 Lenovo IdeaPad 330-15IKB 81DE Speaker Replacement, Back Panel: Schritt 1, Bild 3 von 3
    • Ensure the laptop is powered off.
    • Turn the device over so the bottom is facing up.
    • Remove the 13 6 mm screws from the bottom of the device using a Phillips #0 screwdriver.
    • Carefully glide a Jimmy along the seam of the casing.
    • Remove the back cover of the laptop.
  2. Lenovo IdeaPad 330-15IKB 81DE Speaker Replacement, Battery: Schritt 2, Bild 1 von 3 Lenovo IdeaPad 330-15IKB 81DE Speaker Replacement, Battery: Schritt 2, Bild 2 von 3 Lenovo IdeaPad 330-15IKB 81DE Speaker Replacement, Battery: Schritt 2, Bild 3 von 3
    • Remove the three 6 mm screws from the tabs surrounding the battery using a Phillips #0 screwdriver.
    • Carefully separate the battery connector from the device using a spudger.
    • Lift the battery up and remove it from the device.
  3. Lenovo IdeaPad 330-15IKB 81DE Speaker Replacement, Speaker: Schritt 3, Bild 1 von 3 Lenovo IdeaPad 330-15IKB 81DE Speaker Replacement, Speaker: Schritt 3, Bild 2 von 3 Lenovo IdeaPad 330-15IKB 81DE Speaker Replacement, Speaker: Schritt 3, Bild 3 von 3
    • Remove the connector for the speakers from the motherboard using a spudger.
    • Gently lift the speakers from the device using a spudger.
    • Carefully lift the red wire from its dock along the bottom.
    • Remove the speakers from the device.
Abschluss
Matthew Bridge
245 Reputation
2 Anleitungen geschrieben
UMass Dartmouth, Team 2-1, Konn Fall 2024 Mitglied von UMass Dartmouth, Team 2-1, Konn Fall 2024
UMASSD-KONN-F24S2G1
4 Mitglieder
5 Anleitungen geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 6
Letzte 30 Tage: 27
Insgesamt: 336
