Einleitung
Laptop cooling fans sometimes fail and can have a wide range of symptoms, such as excessive heat coming from the keyboard and "odd" noises such as grinding coming from inside the laptop. As the problem gets worse it can cause your computer to run slower or even shut off. If your Lenovo IdeaPad 330S-14IKB shows any of these signs it may be time to change the fan, this guide will show you how.
Was du brauchst
Place the laptop with its bottom facing up, so you can easily read the labels on the back.
Find the black panel in the top right and remove the three black screws.
Remove the black panel
Your fan will have one black screw connected to it on the left side. Remove this screw.
The fan is connected to a heat sink; leave the heat sink in place but remove the adhesive connecting the two pieces.
Before removing the fan, locate a small set of yellow, red, blue, and black wires on the right side of the fan.
Gently remove them from the connector without pulling on the wires.
Disconnect the large black wire connected to the slot on the side of your fan.
Remove your fan.
3 weitere Personen haben diese Anleitung absolviert.
