Einleitung
RAM is a part that does not typically fail, however it is not invulnerable. If your Lenovo Ideapad 330S-14IKB begins to show signs of failing RAM such as random freezes, blue screens, randomly rebooting, and files becoming corrupted, it could mean it is time to replace it.
Was du brauchst
Begin by placing your laptop upside down so that you can see the labels on the back.
Your RAM will be a blue rectangle, positioned almost in the center of the device.
To remove your RAM, gently pull back on the metal clips holding it in place.
Carefully slide the RAM out of the slot.
Align the notch on your replacement RAM as shown in the previous step with the corresponding slot on the device's RAM slot.
Gently insert the RAM module.
Once it's as far in as it can go, lower it slowly until the metal clips lock it into place.
To reassemble your device, follow steps 6-1 in reverse order.
3 weitere Nutzer:innen haben diese Anleitung absolviert.
