Zum Hauptinhalt wechseln
Lenovo IdeaPad 330S-14IKB USB/SD Ports Replacement
Was du brauchst
  1. Lenovo IdeaPad 330S-14IKB USB/SD Ports Replacement, USB/SD Ports: Schritt 1, Bild 1 von 1
    • Begin by placing your laptop upside down so that you can see the labels on the back.
    Frag FixBot
    Kommentar hinzufügen
  2. Lenovo IdeaPad 330S-14IKB USB/SD Ports Replacement: Schritt 2, Bild 1 von 1
    • Remove the 10 silver screws from the bottom of the laptop.
    • Keep these screws in a safe place like a magnetic board to keep them from getting lost.
    • (Silver, 5.8mm Phillips #0)
    Frag FixBot
  3. Lenovo IdeaPad 330S-14IKB USB/SD Ports Replacement: Schritt 3, Bild 1 von 1
    • Carefully remove the back panel from the laptop.
    • Proceed slowly and use wedges to avoid damaging the panel.
    Frag FixBot
  4. Lenovo IdeaPad 330S-14IKB USB/SD Ports Replacement: Schritt 4, Bild 1 von 1
    • Locate the USB/SD Ports in the top left corner of the laptop.
    Frag FixBot
  5. Lenovo IdeaPad 330S-14IKB USB/SD Ports Replacement: Schritt 5, Bild 1 von 1
    • Remove the two black screws holding the USB/SD port in place.
    • (Black, 3.35mm Phillips #0)
    Frag FixBot
  6. Lenovo IdeaPad 330S-14IKB USB/SD Ports Replacement: Schritt 6, Bild 1 von 1
    • Gently disconnect the black and red wires from the board.
    • Be sure not to pull too hard on the wires.
    Frag FixBot
  7. Lenovo IdeaPad 330S-14IKB USB/SD Ports Replacement: Schritt 7, Bild 1 von 1
    • Remove the blue cable from the board.
    Frag FixBot
  8. Lenovo IdeaPad 330S-14IKB USB/SD Ports Replacement: Schritt 8, Bild 1 von 1
    • Remove your old USB/SD ports
    Frag FixBot
Abschluss
2 weitere Personen haben diese Anleitung absolviert.
sal
459 Reputation
2 Anleitungen geschrieben
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 5
Letzte 30 Tage: 27
Insgesamt: 458
