Einleitung
If your Lenovo IdeaPad 330S-15ARR laptop is overheating, making loud disrupting noises, or just not working, follow this guide for step-by-step instructions on how to replace the fan.
Was du brauchst
Remove the ten 3.3 mm screws securing the back panel using a Phillips #00 screwdriver.
Use a Jimmy or your fingernail to pry the back panel off.
Remove the six 3 mm screws from the black board using a Phillips #00 screwdriver.
Remove the black board.
Disconnect the fan from the circuit board by pulling on the plastic part of the wire towards the fan.
Remove the five 3 mm screws holding the fan in place using a Phillips #00 screwdriver.
