Zum Hauptinhalt wechseln
Lenovo IdeaPad 5 15ITL05 Back (Bottom) Cover Replacement
Was du brauchst
  1. Lenovo IdeaPad 5 15ITL05 Back (Bottom) Cover Replacement, Unfasten the back cover: Schritt 1, Bild 1 von 2 Lenovo IdeaPad 5 15ITL05 Back (Bottom) Cover Replacement, Unfasten the back cover: Schritt 1, Bild 2 von 2
    • Use a T5 Torx driver to remove nine screws securing the back cover.
    • The three screws on the hinge side will be longer.
    Frag FixBot
  2. Lenovo IdeaPad 5 15ITL05 Back (Bottom) Cover Replacement, Step 2 Loosen the back cover: Schritt 2, Bild 1 von 3 Lenovo IdeaPad 5 15ITL05 Back (Bottom) Cover Replacement, Step 2 Loosen the back cover: Schritt 2, Bild 2 von 3 Lenovo IdeaPad 5 15ITL05 Back (Bottom) Cover Replacement, Step 2 Loosen the back cover: Schritt 2, Bild 3 von 3
    • The back cover is held on by plastic tabs around the entire perimeter of the cover.
    • Use plastic pry tools at the seam. I like to start near the hinge.
    Frag FixBot
  3. Lenovo IdeaPad 5 15ITL05 Back (Bottom) Cover Replacement, Step 3 Remove the back cover: Schritt 3, Bild 1 von 2 Lenovo IdeaPad 5 15ITL05 Back (Bottom) Cover Replacement, Step 3 Remove the back cover: Schritt 3, Bild 2 von 2
    • Once all the tabs are loose, you will be able to remove the cover.
    Frag FixBot
Abschluss
3 weitere Personen haben diese Anleitung absolviert.
E N
587 Reputation
3 Anleitungen geschrieben
1 Kommentar zur Anleitung
I would call that the bottom cover. I want to see the back cover of the screen replaced. Including the electronics attached to it!
Bruce Cox - Antwort Teilen
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 14
Letzte 30 Tage: 74
Insgesamt: 2,060
