Zum Hauptinhalt wechseln
Lenovo IdeaPad 5 15ITL05 SATA Drive Replacement/Addition
Was du brauchst
  1. Lenovo IdeaPad 5 15ITL05 SATA Drive Replacement/Addition, Unfasten the back cover: Schritt 1, Bild 1 von 2 Lenovo IdeaPad 5 15ITL05 SATA Drive Replacement/Addition, Unfasten the back cover: Schritt 1, Bild 2 von 2
    • Use a T5 Torx driver to remove nine screws securing the back cover.
    • The three screws on the hinge side will be longer.
    Frag FixBot
    Kommentar hinzufügen
  2. Lenovo IdeaPad 5 15ITL05 SATA Drive Replacement/Addition, Step 2 Loosen the back cover: Schritt 2, Bild 1 von 3 Lenovo IdeaPad 5 15ITL05 SATA Drive Replacement/Addition, Step 2 Loosen the back cover: Schritt 2, Bild 2 von 3 Lenovo IdeaPad 5 15ITL05 SATA Drive Replacement/Addition, Step 2 Loosen the back cover: Schritt 2, Bild 3 von 3
    • The back cover is held on by plastic tabs around the entire perimeter of the cover.
    • Use plastic pry tools at the seam. I like to start near the hinge.
    Frag FixBot
  3. Lenovo IdeaPad 5 15ITL05 SATA Drive Replacement/Addition, Step 3 Remove the back cover: Schritt 3, Bild 1 von 2 Lenovo IdeaPad 5 15ITL05 SATA Drive Replacement/Addition, Step 3 Remove the back cover: Schritt 3, Bild 2 von 2
    • Once all the tabs are loose, you will be able to remove the cover.
    Frag FixBot
  4. Lenovo IdeaPad 5 15ITL05 SATA Drive Replacement/Addition, Disconnect the battery: Schritt 4, Bild 1 von 2 Lenovo IdeaPad 5 15ITL05 SATA Drive Replacement/Addition, Disconnect the battery: Schritt 4, Bild 2 von 2
    • Use the flat end of a spudger to push the square tab on the battery connector and slide it out of its socket.
    Frag FixBot
  5. Lenovo IdeaPad 5 15ITL05 SATA Drive Replacement/Addition, Unfasten the battery: Schritt 5, Bild 1 von 1
    • Use a Phillips screwdriver to remove the four screws securing the battery.
    • Note: Two of the screws on the left in the image will also hold in the SATA drive bracket.
    Frag FixBot
  6. Lenovo IdeaPad 5 15ITL05 SATA Drive Replacement/Addition, Step 6 Remove the battery: Schritt 6, Bild 1 von 1
    • Remove the battery.
    Frag FixBot
  7. Lenovo IdeaPad 5 15ITL05 SATA Drive Replacement/Addition, Unfasten the SATA drive bracket: Schritt 7, Bild 1 von 1
    • Use a Phillips screwdriver to remove the remaining two screws securing the SATA drive bracket.
    Frag FixBot
  8. Lenovo IdeaPad 5 15ITL05 SATA Drive Replacement/Addition, Locate the SATA drive connector: Schritt 8, Bild 1 von 1
    • The SATA drive connector is below the Wifi adapter and to the right of the M.2 NVME slot.
    • It is the second left connector.
    Frag FixBot
  9. Lenovo IdeaPad 5 15ITL05 SATA Drive Replacement/Addition, Prepare SATA drive connector: Schritt 9, Bild 1 von 3 Lenovo IdeaPad 5 15ITL05 SATA Drive Replacement/Addition, Prepare SATA drive connector: Schritt 9, Bild 2 von 3 Lenovo IdeaPad 5 15ITL05 SATA Drive Replacement/Addition, Prepare SATA drive connector: Schritt 9, Bild 3 von 3
    • Lift the flat cable connector.
    Frag FixBot
  10. Lenovo IdeaPad 5 15ITL05 SATA Drive Replacement/Addition, Fold the SATA ribbon cable: Schritt 10, Bild 1 von 1
    • Fold the cable.
    Frag FixBot
  11. Lenovo IdeaPad 5 15ITL05 SATA Drive Replacement/Addition, Insert the SATA drive ribbon cable connector: Schritt 11, Bild 1 von 2 Lenovo IdeaPad 5 15ITL05 SATA Drive Replacement/Addition, Insert the SATA drive ribbon cable connector: Schritt 11, Bild 2 von 2
    • Slide the cable in with the blue/non-contact side facing up.
    Frag FixBot
  12. Lenovo IdeaPad 5 15ITL05 SATA Drive Replacement/Addition, Close the SATA drive connector: Schritt 12, Bild 1 von 2 Lenovo IdeaPad 5 15ITL05 SATA Drive Replacement/Addition, Close the SATA drive connector: Schritt 12, Bild 2 von 2
    • Lower the flat cable connector.
    Frag FixBot
  13. Lenovo IdeaPad 5 15ITL05 SATA Drive Replacement/Addition, Note the orientation of the SATA data and power connectors: Schritt 13, Bild 1 von 1
    • In the example, the power is on top, and data is on the bottom. You'll need to install your SATA drive in the correct orientation.
    Frag FixBot
  14. Lenovo IdeaPad 5 15ITL05 SATA Drive Replacement/Addition, Place the SATA drive in the bracket: Schritt 14, Bild 1 von 2 Lenovo IdeaPad 5 15ITL05 SATA Drive Replacement/Addition, Place the SATA drive in the bracket: Schritt 14, Bild 2 von 2
    • Note the orientation.
    Frag FixBot
  15. Lenovo IdeaPad 5 15ITL05 SATA Drive Replacement/Addition, Fasten the SATA drive to the bracket: Schritt 15, Bild 1 von 1
    • There are 4 screw mount points.
    Frag FixBot
  16. Lenovo IdeaPad 5 15ITL05 SATA Drive Replacement/Addition, Connect the drive: Schritt 16, Bild 1 von 2 Lenovo IdeaPad 5 15ITL05 SATA Drive Replacement/Addition, Connect the drive: Schritt 16, Bild 2 von 2
    • Connect the SATA drive to the connector.
    Frag FixBot
  17. Lenovo IdeaPad 5 15ITL05 SATA Drive Replacement/Addition, Place the drive in the chassis: Schritt 17, Bild 1 von 1
    • Place the SATA drive in.
    Frag FixBot
  18. Lenovo IdeaPad 5 15ITL05 SATA Drive Replacement/Addition, Place the battery in the chassis: Schritt 18, Bild 1 von 2 Lenovo IdeaPad 5 15ITL05 SATA Drive Replacement/Addition, Place the battery in the chassis: Schritt 18, Bild 2 von 2
    • Place the battery in.
    Frag FixBot
  19. Lenovo IdeaPad 5 15ITL05 SATA Drive Replacement/Addition, Refasten the bracket and the battery: Schritt 19, Bild 1 von 2 Lenovo IdeaPad 5 15ITL05 SATA Drive Replacement/Addition, Refasten the bracket and the battery: Schritt 19, Bild 2 von 2
    • Use a Phillips screwdriver to fasten the six screws securing the SATA drive bracket and battery.
    Frag FixBot
  20. Lenovo IdeaPad 5 15ITL05 SATA Drive Replacement/Addition, Reconnect the battery: Schritt 20, Bild 1 von 2 Lenovo IdeaPad 5 15ITL05 SATA Drive Replacement/Addition, Reconnect the battery: Schritt 20, Bild 2 von 2
    • Push the battery connector back into place.
    Frag FixBot
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
E N
587 Reputation
3 Anleitungen geschrieben
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 27
Letzte 30 Tage: 100
Insgesamt: 1,964
